Hello Friends,
Hi Ramesh.
Check the Client setting for the client which are showing error.
Also you can add Host name and IP address of the AOS server at C:\Windows\System32\drivers\etc\ loaction you will find hosts file open with notepad and add (IP) (Domain) like: 190.160.138.4 google.com
Hope this helps!
Hi Umesh,
Thanks for ur reply i will try this and get back to u
Thanks alot Umesh
