Hi everyone,
I’m trying to connect a windows client to a remote server, and I’m finding issues. It’s my frist time I’m not using clickOnce, so any help will be really appreciated.
The instance in the server is configured like this:
The publi IP for the server is XX.XX.XX.XX
I’m trying to connect from the vlient to this direction:
XX.XX.XX.XX:7046/DynamicsNAV110
And I see this error:
“Cannot find any server in “net.tcp://…” The URL is incorrect or the server os not available actually”
Am I trying correctly? Have I forgot any configuration?
Can you ping your public ip-address and get a reponse?
Yes, I can
Have you done a port forward on you router so port 7046 is available
Do you mean to open the firewall? This may be some issue I must talk with the system provider of our client, may be there is some type of redirection…
Have you changed/created a servicetier so it is running NavUserPassword and NOT windows?
Yes, I’m using NavUserPasssword, and the client is installed in different laptops, inside the network. Now the issue is to connect form outside the network
Have you created a databaseuser inside NAV?
Yes, the installation is in use from a longtime ago
Have you created/installed a Certificate on the Server and on the client?
Yes, the certificates are installed into the server, and also in my laptop, where I’m doing the tests
Thanks for your answer Palle, I talk about ClickOnce because untill now, all the remote instalaltions I’ve made hace been with that system, but for this customerI want to connect the windows client. If the URL I’m trying to connect is the correct one, probable I should try to talk with the system provider about the redirections…
In that folder I have NavServiceTRCA. I also have it in revocation list, and in personal folder. It looks that you are also working with the same certificate, so I will say that I’ve used the manual for those certificates to make the installation…
