Hi everyone, a question here before the deepavali weekend…
i am trying to connect NAV 2016 to CRM 2015, and have reached the Microsoft Dynamics CRM Connection Setup page. I keyed in all three columns - Dynamics CRM URL, User Name, Password, then click Test Connection, and i get an error
“the application is set up to support secure connections (https) to dynamics crm only. you cannot use http”
Then i add a “s” after http, and i get
“Metadata contains a reference that cannot be resolved: '”>my_server_name/…/Organization.svc
May i know does anyone faced this before or have any solution on this?
Installation information:
a) NAV 2016 (licensed) - installed in my local laptop
b) CRM 2015 (trial version) - installed in VMWare 12 (which is also installed in my local)
More information:
a) i found out the crm binding is http with port 80, should i change it to https with port 443? was thinking to do this but it needs certificate…
b) the CRM’s Organization Web Service that i check in Deployment Manager is “my_server_name:80”, does this matter…?
thanks for the link! However i tried that before already, doesnt work for me…
I think i will set up IFD with a new VM, not sure if this solve the problem. Hopefully it wont turn out that the native connector doenst support crm on premise.
