Connect two databases in Microsoft Dynamics NAV 2018.
Hi Team,
I was trying to connect two databases together, one of the databases is the Dynamics NAV Database while the 2nd database was created with a table called Attach Document due large volume of attach documents in work place.
From the Dynamics NAV Database, Where I have a table contains the following fields;
S/N Name Data Type
1 No. Code (10)
2 Employee Name Text (100)
3 Employee Age Code (10)
4 Employee Grade Text (30)
5 Employee Mobile No. Text (30)
6 Created By code (50)
7 Created Date Date
From the 2nd Database, where I have a table contains the following fields
  • Document No - Code (20),
  • File
  • File1
  • File
  • Created By - Code (50)
  • Created Date - Date
What i want to is that, when I click attach button from a page in Dynamics NAV Database it should open a connection and allow me to attach the document in the 2nd Database.
Regards.
NAV can have just one Instance per Database, Via SQL you can do!!
