Connect to Navision Server via RTC error
Hello Everyone,
I’m new guy of this website. and need somebody help me resolve the following error.
I’ve Installed the Three Tiers on Three Computers with Navision 2009 SP1 vision. and set SPN on the Navision Server. But Now when i connect Navision through RTC on Navision client computer, the error message pop up.
A server was not found at “net.tcp://192.168.20.109:7046/DynamicsNAV_**_**Service”. Either the URL is incorrect or the server is currently not available.
But in my Navision Server, i use this url to connect navision service and it’s successful.
I’m very appreciate if you can give me some advice.
Gavin
Allow SQL port and NAV 7046 ports in Servers Firewall.
Hello Anil,
Thanks for your reply.
I have allow SQL port 1433 and NAV 7046 in Servers Firewall both NAV server and SQL Server, but yesterday when I set Read SPN and Write SPN on the log on as account running NAV service and SQL service, i can’t start the NAV service, jumped the following error.
“The Microsoft Dynamics NAV Server Cha service on Local Computer started and then stopped. Some services stop automatically if they are not in use by other services or programs.”
Did you have some tools to diagnostic how we should do on three tiers computers to install NAV server?
Best Wishes,
Gavin
Did you check this
http://dynamicsuser.net/media/p/192857.aspx
http://www.mibuso.com/forum/viewtopic.php?t=38495
Dear Mohana,
I have check the documents by your support, and i have restalled Nav 2009 and Sql Server, these are Ok.
But when i run Best Pratices Analyzer for Microsfot Dynamics NAV 2009, it reported that Services account is not a database user, so i execute some commands according Enabling the Object Change Listener.
My question is after finished these proceesure, it also reported that Services account is not a database user.
Do you have encounter this question? Could you give me some advice?
Thanks and wish you a good day.
Gavin
Did you try by adding the service account user to database in SQL?
Yes, i have added the Nav Server service log on account to database.
Gavin
Hi Gavin,
Did you ever find a solution to your problem? If you did, would you mind sharing it with us and if any of the posted answers helped you on the way, then please verify them.
Thank you.
