connect NF Database - odbc - Visual Basic
How can i connect a database for odbc in VB? What code i need? im lost. Thanks. Vísperas. =========
Create a System DSN of C/ODBC and in vb Dim conn As New ADODB.Connection Dim rs As New ADODB.Recordset conn.Open “DSNName” Set rs = conn.Execute(“Select * from Table_Name”) txtCode = rs(“Code”) read the pdf file of c/odbc
the pdf not help me, the code no work not recognize the word “ADODB” :frowning: Vísperas
Visperas, Need to install MDAC (Microsoft Data Access Components). Bill
sorry, how can i do? i install “http://www.microsoft.com/downloads/details.aspx?FamilyID=b41304ca-874f-421d-8820-182f179779a4&DisplayLang=en” now in VB how cain i add the driver? thanks
sorry jose , i forgot to tell you that you have to add the ado reference. if you open VB click on the toolbar - Project - References select Microsoft Activex Data Object 2.6 Library. if it does not work, let me know i will email you the vb file.
thanks, works
