Thank you for the warm welcome Amol!
I tried Savatage’s suggestion but it gave me a boolean error which I was uncertain how to resolve. For ease of reference I’ve copied all the code with comments so you can better see what I am trying to achieve and possibly advise me how best I can proceed. Always many many thanks in advance for your help.
// This code checks to see if the UCITS file export check box is ticked. If it is then the
// the BuildUCITSFile job is called and otherwise the Ashburton file is created.
IF
UCITS_File_Check
THEN
BEGIN
OpenMethod := 2; // 1=adOpenKeyset; 2=adOpenDynamic; 3= adOpenStatic
LockMethod := 3; // 1=dLockreadonly; 2=adLockPessimistic; 3=adLockOptimistic; 4=adLockBatchOptimistic
CREATE(ADOConn);
// build connection string…
ConnStr := ‘Driver={SQL Server};Server=MYSERVER;Database=NAVISION;Trusted_Connection=yes’;
// now connect to sqlserver database…
ADOConn.Open(ConnStr);
// build sql string…
SQLstring := STRSUBSTNO(‘EXEC msdb…sp_start_job ‘‘BuildUCITSDailyPrices’’’);
// run the dts job to export our file into sqlserver…
ADOConn.Execute(SQLstring);
ADOConn.Close;
// clear connection…
CLEAR(ADOConn);
MESSAGE(‘UCITS File preview completed’)
END
ELSE
BEGIN
CLEARALL;
// the following statement resets any previously defined filters…
“FDR Fund Price”.SETRANGE(“Prices Authorised”);
“FDR Fund Price”.SETRANGE(“Dealing Date”);
// first obtain the total count of the dataset based on entries for TODAYS date …
// im passing the CURRENTDATETIME value to the DT2DATE built-in which strips out the time portion
// in order for me to be able to use a clean date comparison later…
// testdate := 161008D;
// “FDR Fund Price”.SETFILTER(“Dealing Date”, ‘= %1’,testdate);
“FDR Fund Price”.SETFILTER(“Dealing Date”, ‘= %1’,DT2DATE(CURRENTDATETIME));
dataport_record_count := “FDR Fund Price”.COUNT;
IF
dataport_record_count = 0
THEN
ERROR(‘ERROR - No records to export for todays date’);
// now set a table filter to delimit the returned count…
//Here is the problem part I think what I need to do is exclude funds that begin “AH%” from the filter so the code will select the old funds as normal and ignore these //new funds which are handled by a separate process
“FDR Fund Price”.SETFILTER(“Prices Authorised”,’= YES’);
// now retrieve count for only the prices that have been verified…
verified_count := “FDR Fund Price”.COUNT;
IF
dataport_record_count = verified_count
THEN
BEGIN
// MESSAGE(‘all records have been verified : ok to export file’);
// First generate the output txt file for subsequent export…
// the following dataport statement contains a “FALSE” statement
// this is to suppress the display of the request form…
// interestingly, if you select “no” from the dataport properties
// for displaying the request form, it still gets displayed…
//ADOConn Automation ‘Microsoft ActiveX Data Objects 2.7 Library’.Connection
//DbConnection := Automation ‘Microsoft ActiveX Data Objects 2.7 Library’.Connection
//ADOrs Automation ‘Microsoft ActiveX Data Objects 2.7 Library’.Recordset
//ConnStr Text : 200
//AnzCount Text 30
//OpenMethod Integer
//LockMethod Integer
//Name Text
//Str Text 200
// now create odbc connection, and perform export…
// Test ODBC-Connector
CREATE(ADOConn);
ConnStr := ‘Driver={SQL Server};Server=Ashsrv08;Database=LocalUtility;Trusted_Connection=yes’;
SQLstring := STRSUBSTNO(‘EXEC msdb…sp_start_job ‘‘BuildNavisionFundpric2’’’);
//the following “SLEEP” statement gives enough time for the ftp dts launched prior to finish
//before the dataport attempts the import.
//without it, what happens is that the code tries to
//open the file PRIOR to the ftp dts completing, clearly a problem…
SLEEP(4000);
// disconnect from database…
ADOConn.Close;
CLEAR(ADOConn);
// first dataport run builds FULL prices file including internals
DATAPORT.RUN(50055,FALSE);
SLEEP(4000);
// second dataport run builds the distribution prices file (minus internal prices)
DATAPORT.RUN(50049,FALSE);
MESSAGE(‘Preview prices files successfully generated…’);
END
ELSE
MESSAGE(‘ERROR : all prices have to be authorised before export allowed’);
END;
