condition based sum in select statement X++
Hello All,
I want to write X++ select statement for getting sum based on condition; below is my SQL select statement.
select
SUM(Case when XQty =0 then YQty else XQty end) from XXXtable
Please suggest if this is achievable thru X++ sum function.
Thanks!
Hi Falguni,
if you are checking the condition on both quantities and returning the values based on that, try something as follows…
select sum(xqty),sum(yqty) from xxtable;
if(xqty == 0.00)
return yqty;
else
return xqty;
note: It is just pseudo code i have not tested in x++ code editor.
Ven
You can’t do exactly the same, but you can easily get the same result by two queries:
select sum(XQty) from t1;
select sum(YQty) from t2
    where t2.XQty == 0;
t1.XQty + t2.YQty
Thanks for getting back, I suppose there is not any direct way to achieve this. Probably I ned to loop thru or trick with Martin’s answer.
