HI,
I have a text file that contains two fields , one for the date and one for time . Each fields is stored in a variable.
I want to concatenate these two variables and put it in SalesTable.CreatedDatetime.
I have tried : str2datetime(date1+’’+date2,123) but it doesn’t work.
Can you help me, please ?
Thanks.
Hi Marc,
Please check the date and time format in the text file.
If the date and time format is correct then, str2datetime will work perfectly. Please refer this link https://msdn.microsoft.com/en-us/library/cc569557.aspx
For example:
str2datetime(‘21/01/2014 10:00:00’, 123)
seconds is required.
You can also use date time util. For example:
DateTimeUtil::newDateTime(1\1\2014, str2time(‘10:00’))
Hari
Check if the string values are valid,
createdDateTime is a system field, this can be overwritten during the insert.
See \Classes\IntercompanySyncNotesTask\writeDocuRef
It all depends on the format; unfortunately all what we can say so far is that your format isn’t valid for str2datetime().
Either modify the string to a valid format, or use a more clever way for parsing strings to date and time, such as System.DateTime::ParseExact().
An alternative solution would be parsing date and time separately and putting them together by DateTimeUtil::newDateTime().
The format for the date is dd/mm/yyyy
and the format for the time is : hh:mm
As you already found, dd/mm/yyyyhh:mm isn’t a format supported by str2datetime(). This is how you need to transform your data, if you want to use str2datetime():
str dateStr = '31/12/2015';
str timeStr = '12:34';
str s = strFmt("%1 %2:00", dateStr, timeStr);
utcDateTime dt = str2datetime(s, 123);
Thanks a lot guys !
Your solution works well in a job, Martin but it doesn’t work in my class. I think so we can’t modified SalesTable.createdDateTime as says Kranthi.
You’re mixing two separate things. My solution works correctly; that you’re using the value for a wrong purpose has nothing to do with my conversion from string to datetime.
I didn’t comment on CreatedDateTime field, because it was already said above.
