Hi guy,
I’ve met some following errors while compiling application:
How effect to the system ?
Please help me to fix this bugge.
Thanks in advanced!
Hi guy,
Thanks in advanced!
i cant able to see the error message.copy and paste(dont use picture) the error message.
I’ve attached the error screen in previous posted.
Here is the error message:
Error executing code: Global (object) has no valid runable code in method ‘XMLString’.
(C)\Classes\Global\XMLString
(C)\Classes\xRecord\xml
(C)\Classes\SysCompilerOutput\xmlExport - line 156
(C)\Classes\SysCompilerOutput\exportLog
(C)\Classes\SysCompileAll\compile - line 14
(C)\Classes\SysCompileAll\main - line 8
(C)\Classes\MenuFunction\run
(C)\Classes\SysHelp\processMenuFunction - line 85
(C)\Classes\SysHelp\processStandardLink - line 26
(C)\Classes\SysHelp\processOnEventNavigate - line 40
(C)\Classes\SysHelp\onEvent_BeforeNavigate2 - line 27
(C)\Classes\FormActiveXControl\onEvent_BeforeNavigate2
Is the system customized at all or is it vanilla? I see you have the checklist open…did you skip any steps?
