compare Financial dimension
is there a method to compare Financial dimension in ax201é
Do you mean default dimensions or ledger dimensions? And can you tell us more about your requirements?
No agreement dimension,
i have create new method its work ,
thank you
Although I still have no idea what you needed, can you please share your solution? Somebody else might have the same requirement.
i have create this function to compare two dimension like this :
public static Boolean CompareDim(DimensionDefault _DimFrom, DimensionDefault _DimTO) {
DimensionAttributeValueSetStorage storage_1,Storage_2;
int attributeCount, attributeIndex;
str attributeValue,AttributeVAlue1;
boolean ret = true;
// Get storage
storage_1 = DimensionAttributeValueSetStorage::find(_DimFrom);
Storage_2 = DimensionAttributeValueSetStorage::find(_DimTO);
// Add attribute count
attributeCount = storage_1.elements();
for (attributeIndex = 1; attributeIndex <= attributeCount; attributeIndex++){
// Add attribute value
attributeValue = DimensionAttributeValue::find(storage_1.getValueByIndex(attributeIndex)).getValue();
attributeValue1 = DimensionAttributeValue::find(Storage_2.getValueByDimensionAttribute(storage_1.getAttributeByIndex(attributeIndex))).getValue();
//COmpare Values
if( attributeValue != attributeValue1)
return False;
return ret;
For your information, these are default dimensions.
