Compare 2 instance
hi all
is there any way to compare two different instance.
suppose i want to compare my test instance and production instance,
is thr anyway to acheive this???
suggest me some ideas
thanx in advance
Instances of what? X++ code, data in database, or something else?
hi martin
thanx for ur reply
want to compare 2 instance X++ code,
is it possible???
If you really need to compare complete applications (and not just specific objects), copy layers from one environment to Old subfolder in application folder of the other environment, restart AOS and use Tools > Development Tools > Code upgrade > Compare layers to compare individual layers (e.g. CUS and CUS (old)). The approach is similar even in AX2012, but you have to use baseline model store instead of the Old folder.
hi martin
its dont.
thanx a lot for ur help :slight_smile: :slight_smile: :slight_smile:
Hello Martin, This is very useful information, but I have a little variant on this question. I am using AX 2012 and I don’t want to compare all the application as you said, but I need to compare a lot of objects (more or less 3.000), and of course, it is very hard to do it manually. My purpose is to get a list of all the objects that have differences, in order to later, check the differences manually. Do you think that it is possible to achieve it through baseline model store?
Yes, putting the version to compare to the baseline modelstore makes perfect sense. Nevertheless you’ll have to design your logic by yourself. Maybe you’ll compare all layers and ignore some objects, or you’ll implement your own comparison logic that will skip some objects.
Hi Martin,
I want to compare a instance between 2 environment ( lk development and production), is there any best way to do dat?
sorry, i want to compare data between 2 instances( like development and production environment) please can any body give suggestion
Please read the suggestion above.
