How can i make the logo for our company in navision 5 : export to microsoft office word to send the report to ms-word the logo on the file is not that of our company
we change the logo in company information card and still having the LOGO of Cronus ?
go to administration, IT administration, General, Manage Stylesheet…There you will be able to export and import it. The picture is encoded. so you need to encode your picture too.
To replace:
-one way is to follow the instructions from the whitepaper
-another one is using the style sheet editor for nav from microsoft.
or
1.export the stylesheet. (xslt from administration and also direclty from the toolbar)
2.replace the picture in word
saved it as word XML in word
open the (word xml) file in an editor and copy the picture tag
open the stylesheet xslt in an editor and repalce the picture tag with your picture
reimport it to nav
If you need more help let me know then I post the complete description.
in objecy designer, go the the report you want have your logo, click design button into the design mode, click the view->, now you will see the layout of the report. use the toolbox add a picture box to you report. and set the picture box’s property by using the logo you want. Be ware there are some restriction about the picture box, I would suggest using photo shop to modified the pixture first.
Jouhayna, please mark the solution(s) which helped you to solve the issue by clicking the “Verify Solution” button in the post(s). This will earn you points and show others that your problem is solved.
