Company does not exist error in AIF
I need your help to resolve below mentioned issue in our AX2012 R2 with CU6 environment.
Subsystem: Line=1, Pos=411, Xpath=/CustPaymJournal/LedgerJournalTable[1]/LedgerJournalTrans[1]
Exception message: Company does not exist.
I am getting this exception while using create operation of LedgerCustPaymJournalService via file system adapter. Used XML file is attached for reference.
<?xml version="1.0" encoding="utf-8"?>
<Envelope xmlns="http://schemas.microsoft.com/dynamics/2011/01/documents/Message">
<Header>
<MessageId>{1AA736D7-0271-4EE9-A83D-67A18B5E8242}</MessageId>
<Action>http://schemas.microsoft.com/dynamics/2008/01/services/CustPaymJournalService/create</Action>
</Header>
<Body>
<MessageParts xmlns="http://schemas.microsoft.com/dynamics/2011/01/documents/Message">
<CustPaymJournal xmlns="http://schemas.microsoft.com/dynamics/2008/01/documents/CustPaymJournal">
  <LedgerJournalTable class="entity">
    <CurrencyCode>KES</CurrencyCode>
    <DefaultDimension xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
    <JournalName>SCBKR</JournalName>
    <JournalTotalCredit>200</JournalTotalCredit>
    <JournalTotalDebit>200</JournalTotalDebit>
    <Name>Test AIF</Name>
    <LedgerJournalTrans class="entity">
      <AccountType>Cust</AccountType>
      <AmountCurCredit>200</AmountCurCredit>
      <Company>sil</Company>
      <LedgerDimension>
        <DisplayValue xmlns="http://schemas.microsoft.com/dynamics/2008/01/sharedtypes">C1251</DisplayValue>
        <Account xmlns="http://schemas.microsoft.com/dynamics/2008/01/sharedtypes">C1251</Account>
        <Values xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" xmlns="http://schemas.microsoft.com/dynamics/2008/01/sharedtypes" />
      </LedgerDimension>
      <MarkedInvoice xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
      <OffsetAccountType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
      <OffsetDefaultDimension xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
      <OffsetLedgerDimension xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:nil="true" />
      <PaymMode>Cash</PaymMode>
      <TransDate>2017-02-15</TransDate>
      <Txt>Test</Txt>
      <CustVendPaymJournalFee class="entity">
        <FeeCurrency>Fe1</FeeCurrency>
        <FeeId>FeeId1</FeeId>
      </CustVendPaymJournalFee>
      <CustTransOpen class="entity">
      </CustTransOpen>
    </LedgerJournalTrans>
  </LedgerJournalTable>
</CustPaymJournal>
</MessageParts>
</Body>
</Envelope>
Make sure Client config WSDL is refreshed, And I believe you are hitting similar error related to below thread. Check if your service accounts are all aligned as suggested.
community.dynamics.com/…/106250
