Can anyone please explain how the code/properties work to control the bit map comment box? The box lights up(turns white)when you enter a comment in a form such as the Customer Card. Thanks in advance.
Never mind I found the answer here http://www.navision.net/forum/topic.asp?TOPIC_ID=4820&SearchTerms=comment,bit,map
