Hi
Please help me with the columns under dbo.Windows Login table
thanks
Hi
thanks
How? [:)]
Actually there is nothing to do with this table - it’s for system use, no need to tamper with it.
When i am accessing windows login from tools – security i came across the following error.
The system failed to retrieve the global catalog from active directory. This maybe caused by network problems,or it may be caused by a lack of active directory functionality on ur machine or on the network. Active directory functionality is not available
I can’t access the login id’s from the data base.
So i look into the database table there in the table i found Time stamp - null; SID - null
I thought some thing should be there other than this so
aumn,
Please do not cross post the same question, even rephrased - I answered you there: http://dynamicsuser.net/forums/t/32623.aspx just 3mins ago… If you need additionl info, go on posting in the SAME thread, instead.
Second - what part of
you didn’t understand? Especially in Active directory functionality is not available?
Once more - this VERY OBVIOUSLY is AD issue, not Navision.
