CLR Exception occurs every time the export to XXXX (using recurring job) and found nothing to transfer
The user gets many of the following exceptions in event log. Going through these exceptions consumes lot of time if we want to find any error.
Error message:
Microsoft.Dynamics.Ax.Xpp.ClrErrorException: SysIntegrationActivityBatchTask-run Error message: SysIntegrationActivityBatchTask-run Package file id is not generated for data job id ‘Azure DB Global incr push-2017-06-15T10:21:36-EC196DEA9DE64D09A3E51F78F6D7E5CD’, Stack trace: at Dynamics.AX.Application.DMFIntegrationBridge.Export(IntegrationBridgeContract bridgeContract)
Repro Steps :
Repro steps:
Turn on CT on an entity
Publish entity to XXXX
create an export data projekt (with XXXX) with the entity
create a recurring job scheduled every 2 minute (to not have to wait so long)
Watch eventlog of server, after second export, nothing should be exported and the exception is thrown.
Do you know what process is causing this error or explain it?
Exporting data. If it didn’t find anything to export, this error occurs. This is due to a fact that the user is using change tracking and it will only export the changes. If there hasn’t been any changes , this error occurs. it shows as error, but may be called as an exception. This a recurring job . And with these errors filled up in the event log, it is difficult to find the actual error.
A bit more details about your export. What is being exported and how?
Please provide all the necessary details, so that someone trying to help you will not spend time in extracting information from you.
