Have you run the Close Income Statement job on each fiscal year you closed?
The batch-job only works on 1 fiscal year at the time.
So if you put 31.03.09 as the End Date in the Request form, then you’ll end up closing entries with dates ranging 01-04-08…31-03-09.
But if any entries have dates before 01-04-08, then they will not have been included.
If this is not the reason, then i can only think of Prior-Year Entries as the reason for the difference.
Filter 01.04.09 includes transactions posted on THAT date, if such exist, and these already belong to next FY. To see zero balances of P/L accounts (as should be for closed FY), the filter must be LAST day of FY, not first, as you set it.
Besides, normally closing date postings are included, when you look at the CoA, but you might have excluded them - check that, too. Closing entries in your case will have PostingDate C31.03.09.
