Client Crash during Startup
Greetings,
From yesterday, AX client crashes when I open the client.
Event viewer it shows 2 errors :
Tried solution:
Tried solution:
I tried deleting %appdata%/local/*.auc file and .kti files in client pc.
also, tried restarting AOS in server.
What happened before you got the error for the first time?
Does it happen to all users? On all machines?
Greetings Mr. Martin,
Yes, from All clients…Same issue…
regards
And the other questions?
BTW also check suggestions in this thread.
Reg. other questions…
Nothing happened…
Yesterday evening …IT person from my client called and told me about this error.
I asked him to check other clients…He replied same…
regards
Greetings,
As per Mr. Martin Drab’. I even checked other threads…
Since we got two servers one for production and other for Test. From the same client PC I tried to connect with Test Server. It works fine.
I am thinking of creating a new AOS in the production server pointing to the same DB as it was. And in client PCs… I can give new AOS in production Server. Hope it should work.
Or…any of our group consultants has any more tips…Pls. share.!
regards
You can also analyze the crash dump in WinDbg to see call stacks, values of variables etc. Also note that some basic analysis can be done in LCS (Crash and Hang Analysis service).
Greetings,
Thanks Mr. Martin.
Problem Fixed…
Regards
Please share the solution with us. It may help other people in future.
