hi All,
i have a tree control, on which i set the check box property to Yes. Now where is the click event of the check box?
thanks
hi All,
thanks
u can override the click event by overriding modified or clicked method for that Checkbox.
U can do this by right clicking on the methods node of checkbox and select override method and select modified or clicked mothod and write your code in that method.
U have to override the modified method of the checkbox
NO…NO
i am talking about the treecontrol. If you set the Checkbox property to ‘YES’ on the treecontrol , then the checkbox will appear on each node of the tree. I want to know where is the checkbox event of these checkboxes
You need to override the mouseDown and keyDown events of the treeControl, where you need to restrict the logic execution only for the check box select/un-select.
Go through the similar kind of implementation in \Forms\LedgerJournalPostControl
Hi Kranthi,
Thanks a lot !!
Ur reply alway come with nice solution…,[Y]
thanks
MAnish
Hi Kranti ,
can i check the checkbox through code. Right now i am checking it through the mouse click. . I used following code:
child.stateChecked(true); //but this does not work.
