Is there any way to clean the Isolate Storage?
I know I can do: IsolateStorage.Delete(key), but what I want to do is delete ALL the keys, because there are millions and I do not know the keys and I want to clear them all.
Thank you
Thank you
Yes, there is a way to clean the Isolate Storage in your application. You can use the IsolateStorage.GetEnumerator() method to retrieve all the keys in the Isolate Storage and then delete them one by one using a loop. Here is an example code snippet that you can use:
using System.IO.IsolatedStorage;
// Create an instance of the IsolatedStorageFile class
IsolatedStorageFile isoStore = IsolatedStorageFile.GetUserStoreForApplication();
// Retrieve all the keys in the Isolate Storage
string keys = isoStore.GetFileNames(“*”);
// Loop through all the keys and delete them
foreach (string key in keys)
isoStore.DeleteFile(key);
This code retrieves all the keys in the Isolate Storage by using the GetFileNames("*") method, which returns an array of strings containing all the keys. It then loops through the array and deletes each key using the DeleteFile(key) method.
Note that this code will delete all the keys in the Isolate Storage, so make sure that you do not need any of the data before running this code.
This is a ChatGPT answer, and as all the ChatGPT’s answers for AL they do not work
