Good morning,
When I press the bottom selectall i want to select all the record and the flags are true but i can’t do that.
then when i press again the bottom all the flags are false.
Thank you
What exactly is your question?
I could not make out what you really want to ask …
Hi Andrea,
There are many variations to do this. If you have a checkbox field in the table, write below code by over riding clicked method under “Select all” button -
while select
ttsbegin;
Things to remember -
- Write above code after super();
- Under deselect all button, do the reverse. Hope you know what I mean.
