Hi
Here i have one customized form is there. in that form when i check the checkbox i need to filter the POStatus::Received only its working fine me.
When i uncheck the check box i need to filter the All POStatus data its not working
Please suggest me any one and check the code if anything is wrong correct me.
Modified() code
public boolean modified()
boolean ret;
if(CheckBox.value() == NoYes::Yes)
purchtable_ds.NonPOFilter();
else if(CheckBox.value() == NoYes::No)
PurchTable_ds.removeFilter();
ret = super();
PurchTable_ds.executeQuery();
return ret;
kranthi
September 11, 2017, 11:06am
2
Have a look at InventQuarantineOrder form. (see how the view ended checkbox works)
Hi
i found the solution.
boolean ret;
//purchtable_ds.removeFilter();
PurchTable_ds.query().dataSourceName(“PurchTable”).clearRanges(); // i added this line its working
ret = super();
return ret;
Thanks for giving reply
kranthi
September 11, 2017, 11:44am
4
You don’t have to do that. Just call the executeQuery in that method and handle applying ranges in executeQuery method. Have a look at below methods.
\Forms\InventQuarantineOrder\Data Sources\InventQuarantineOrder\Methods\executeQuery
\Forms\InventQuarantineOrder\Methods\showComplete
OK kranthi,
i will try and update you.
