Hi I have a text box control witht the name txtBestaandDatum
And I try to check if that text box is empty:
IF CurrForm.txtBestaandDatum := ‘’ THEN BEGIN
ERROR(‘Datum kan niet leeg zijn’);
Thank you
Thank you
You cannot check the control name. You need to check the actual field/variable assigned as the source of the control. So don’t use the CurrForm.
You cannot check a control. Why don’t you use the variable or table field which is source expression to the TextBox.
Hope this helps.
Thank you
