Changing table stucture of system tables
Hi all, I have to add a new field in Item table (nr. 27), but the program does not allow it. Anyone knows how to change the structure of base system tables? Thank you in advance Mikel.
Look like your license does not include the Table Designer (Granule 7,130). Then it’s not possible for you to add fields
And you can (anyway) just add fields in the ID range of 50000 to 99999. So make sure that you start with one of these ID’s.
