To open a different database from default database in RTC, I went to config file and changed the Database Name from " Demo Database NAV (6-0)" to “Aqua”, and restared the DynamicsNav service. But still the RTC is opening the default Cronus. I even checked the Event Logs, there are neither errors no warnings.
Did you ever find a solution to your problem? If you did, would you mind sharing it with us and if any of the posted answers helped you on the way, then please verify them.
