We have MS dynamics NAV running. Data base is in SQL Server 2005.
What i did when using NAV application was clicked on tools and Security then changed the password.
later again i went to tools – security – Data base logins.
We have only one user login for which i wanted to change the user id.
when i entered the user id which was not there in the database. i got a warning message that the user id does not exist in the database. from then i could not open my NAV application as the user name and password are incorrect.
i have changed the password to dynamics NAV login. then i tried to change the username also. but as the user name i entered is not in the data base, a warning displayed and now i could not able to login to the application. Please help me
I have created a new user in the database. Given the user permission as db admin.
I could able to login to the application getting warning as you have no permission to run the MBS menu suite and also another ’ you don’t have permissions to read General ledger’
Surya I mean Aumn (because you changed your username), this is the third time that you started a topic about the same thing, and the third time it was merged into the original one. Please stop creating new topics for the same issue.
