It will only make your employees work more efficient, as they don’t have to change active company when launching AX.
They will be a lot less annoyed by the switching companies every time they login to AX.
Just so that you know - company can also be specified in ‘Company’ field under General tab DAX Client configuration utility. This setting will over ride the ‘Start company accounts’ specified within DAX.
