Change the BC standard VAT to base on unit cost instead of unit price
Cambodia, has new regulation by changing the standard tax to use based on unit cost (COGS) , I have try to find the way and which code I need to subscribe for my custom logic, and I came up with but not sure it is the right way, anyone please help and advice, thanks
[EventSubscriber(ObjectType::Codeunit, Codeunit::"Sales-Post", 'OnRunOnBeforeCalcVATAmountLines', '', false, false)]
    local procedure AdjustVATBasedOnUnitCost(SalesHeader: Record "Sales Header")
    var
        SalesLine: Record "Sales Line";
        VATPostingSetup: Record "VAT Posting Setup";
    begin
        // Filter Sales Lines related to the current Sales Header
        SalesLine.SetRange("Document Type", SalesHeader."Document Type");
        SalesLine.SetRange("Document No.", SalesHeader."No.");
        // Loop through the filtered Sales Lines
        if SalesLine.FindSet() then
            repeat
                // Ensure VAT calculation applies only to lines with a VAT %
                if SalesLine."VAT %" > 0 then begin
                    // Retrieve the VAT Posting Setup record for the VAT Prod. Posting Group and VAT Bus. Posting Group
                    if VATPostingSetup.Get(SalesLine."VAT Prod. Posting Group", SalesLine."VAT Bus. Posting Group") then begin
                        // Use the VAT Posting Setup to calculate VAT Base Amount and Amount Including VAT
                        // Here, using Unit Cost instead of Unit Price
                        SalesLine."VAT Base Amount" := SalesLine."Unit Cost" * SalesLine.Quantity;
                        // Calculate the Amount Including VAT
                        SalesLine."Amount Including VAT" :=
                          SalesLine."VAT Base Amount" +
                          (SalesLine."VAT Base Amount" * VATPostingSetup."VAT %" / 100); // Use VAT % from the setup
                        // Save changes to the Sales Line
                        SalesLine.Modify();
                    end;
                end;
            until SalesLine.Next() = 0;
    end;
