Hi Felix, your post is pretty unclear, could you please clarify what you are asking. Also you have posted to the wrong forum, so its unlikely you will get an answer. We need to know at least what product you are using. NAV, GP, AX, SL,etc.
if am comparing the expense statements from the last yer with current yr. If i didnt enter the last yr. then the system wont allow me to compare.Is it possible to inser an existing yr with the current yr. E.G. I v enter acc.period as 01.04.07 - 01.04.08. Now shall i able to insert a yr as 01.04.06 - 1.04.07. Is it possible…?
