Hi guys.
I have an issue with changing report DP type from regular (ex. SrsReportDataProviderPreProcess ) to TempDB ( SrsReportDataProviderPreProcessTempDB). I have an LedgerTransStatement report, which originally was TempDB report, but someone from my team changed it while developing some modifications. Now I can’t change it to TempDB, because I’m getting errors:
Error executing code: Wrong argument types in variable assignment.
Stack trace:
(S)\Classes\SrsReportDataProviderPreProcess\parmUserConnection - line 3
(S)\Classes\SrsReportRunRdpPreProcessStrategy\execute - line 24
(S)\Classes\SrsReportRunRdpPreProcessStrategyTempDB\execute - line 6
(S)\Classes\SrsReportRunRdpPreProcessService\executeWithContract - line 82
(S)\Classes\SrsReportRunRdpPreProcessService\executeRDLClasses - line 38
(C)\Classes\SrsReportRunService\preRunReport - line 26
(C)\Classes\SrsReportRunImpl\preRunReport - line 12
(C)\Classes\SrsReportRunController\runReport - line 45
(C)\Classes\SrsReportRunController\run - line 6
(C)\Classes\SysOperationController\startOperation - line 10
(C)\Classes\SrsReportRunController\startOperation - line 12
(C)\Classes\LedgerTransStatementController\main - line 8
(C)\Classes\FormFunctionButtonControl\Clicked
Here I have regular assignment, which should work, but it gives this strange error. Note, that it does not using “TempDB” version of the class. I have no idea how to fix it. I have tried small CIL compilation, but it didn’t worked.
Compile forward isn’t enough.
