There are no Change Log Entries if a record has been renamed ? I have enabled change Lo Setup and add some fields in a Table. I see that trigger OnGlobalRename in Codeunit1 is not fired. Is this a bug ?
How did you rename the record ? Within a form manually or with Rec.RENAM(Bla) code ?
I have renamed the record within a form
Please check if the GetGlobalTriggerMask is getting called from CU1
