Hi ,
Normally if we want to choose some date, that dropdown calender shows days from sunday to saterday. But my client want that sequence from monday to sunday.
Is it possible to change it in Ax 2012. If anyone has idea, pls share it.
Hi ,
Hi ,
Check Global.firstDayOfWeek() , usually It takes 6 , try to change it to 0 and see the calendar lookup. Hope this helps .
Thanks Jyothi. I found the same. It will work.
