Change a standard Excel sheet design
hello guys,
there is an excel sheet report: general ledger >reports > transactions > financial statement > save > ok after save , it opens on excel with a standard design , i want to change this design but i don’t know how or where to do it. anyone can help me with this please. thanks and kind regards
Have you found any solution. I have the same problem
are u talking about AX 2012.?? if yes then class ‘LedgerBalanceSheetDimPrintExcelEngine’ is the one you have to debug and if you are looking in to convert to pdf just ping me.
Can you tell me how to show only one page,not two or more. I need that.
Thank you
yes, you can delete the base sheets through code. That will solve ur issue. :slight_smile:
