CFMD VAR Manual
Hi
Doing CFMD for one of the add-on on NAV 2013 R2 . Stuck with VAR Manual .
How do we create VAR Manual for CFMD Project?
Anybody have any experience ? or any example
Hi Amol,
With many of the requirement for CfMD it depends on how your add-on will be positioned. If you are actually producing the add-on as a VAR having it’s own add-on a manual likes this does not add value to your add-on. If you have a clear ‘story’ on this towards MS (or de facto Lionbridge who will be testing your add-on) you can do with little or none VAR documentation.
In general the manual should explain how you’re add-on works and who it can be incorporated into the database(s) a potential VAR is working with and applying your add-on to.
Note: if you enlist for a test with pass guarantee, you will get the chance of learning-by-doing. I.e. every omission/failure/error in whatever part of your add-on you will get feedback on and directions on what should be done to improve it.
b rg
Luc
Thanks for clarifications Luc…
I came across this document, maybe can be helpful for you:
http://microsites.lionbridge.com/veritestcertification/SiteAssets/SitePages/dynamics-software-solution-test/Microsoft%20Dynamics%20NAV%202015.pdf
You’re welcome, Amol.
Great Going Mohana .Too Fast…
