Hi Experts,
In AX 2012, I am working on a MorphX report(Already developed) which has email sending functionality and the code is fine.
When I try to send the email, It is throwing below error,
“Method ‘send’ in COM object of class ‘CDO.Message’ returned error code 0x80040211 () which means: .”
and when I try to send any other report(SSRS) by email, it is working fine. So, there shouldn’t be any issue with email parameters.
So, I am puzzled here.
Please drive me in correct direction if I am missing something.
Thanks in advance.
Verma.
Did it ever work? Or has it stopped working after recent changes?
Thanks for the reply, Abhinay.
The report was developed. But, was not release for Prod.
As per client, it was working in test earlier.
Perhaps this link holds the key.
The environment has only one AOS.
As I said, the other reports are able to send the emails.
I have done below things as well.
I have generated CIL.
The user has access to the attachments path.
Restarted the AOS twice.
Still the above error is coming.
Please give suggestions on this.
Posting little late…
Here is the solution I found after all the above steps are performed.
- I have used
interopPermission = new InteropPermission(InteropKind::ComInterop);
interopPermission.assert();
and
CodeAccessPermission::revertAssert();
for proper assertions and permissions.
- Make sure the email account which you are using(From address) should have proper access and permissions on email server.
and they worked for me.
Chiranjeevi
