On January 1st of each year, we have our system set up to change the Prefix and Suffix of the Case 3. We use this format: xx-xxxxxx
Each year the prefix changes, so we are currently on 22-XXXXXX
The issue we have is that our suffix is not resetting to 000000, it just keeps continuing.
We are using a Solution called eBECSAutoNumber. The process is Activated. The Year is Order # 1, and the Number is Order # 2. So it seems that it works correctly for Order # 1, but not going to # 2.
Number Format
Format String 000000
Starting Number 1
Reset On Date Change Year
Does anyone have experience setting up the auto-numbering like above and have any tips?
We are not using this:
Microsoft Power Platform admin center: Environments > [select an environment] > Settings > Data management > Auto numbering.
