Capacity Unit of Measure 100/Hr or Blank
Hi All, I have a question in Capacity unit of measure definition options. under which specific scenario’s the options Blank and 100/Hr are used? As I understand the Blank option is used to define unlimited capacity and 100/HR option is to fix an approximate units coming out from the center per hour, its hundred units perhour and based on quantity specified on the routing line the exact amount is calculated in orders. Is that right or was it meant for something else? Any kind of help is appreciable. Thanks in advance best Regards Sreekanth
Hi, Let say you have operation that takes 1 hour 30 minutes. In this case you will base on UOM routing line Run Time shoul be: Blank - 5400000 (Blank means milliceconds) 100/HR - 150 (100/Hr means one hundred part of an hour) Minute - 90 Hour - 1.5 Day - 0.0625 (Day mean 24 hours) Inside Navision plans in milliseconds.
HI Valentin, Could u give any scenerio for 100/Hour, 'cos it still getting me confused…
I tried with an Item with Fixed orde quantity and its routing is linked with workcenter whose capacity unit of measure is 100/hr.which following gives me confusing result. Pls help how to evaluate it
