Hi Experts,
I need to find out how these below field values are calculated in capacity load form of the resource group. Please Help me on this
1)Oper.reserved
2)Job Reserved
3)Reserved
Thanks in Advance,
Mark.
Do you have access to a development environment, so you can look at the definitons
What is the name of the form?
Which version of AX are you using? Do you need answers for both D365FO and AX 2012, as your tags suggest?
Hi Mark, there is quite a bit that goes into those values. First, the calendars that are associated with Production resources and used for the operations/jobs helps define the capacity. I.e. if I have an 8 hour calendar and no jobs, I have 8 hours of capacity.
The reservations come into play once orders have been scheduled with operations and jobs that occur at those resources. The time of those jobs decrements the available capacity for the resource/group once the order is scheduled. The difference between oper. reserved and job reserved depends on if you are using Operations scheduling or Jobs scheduling. I believe the Reserved column is a sum of those two values.
Hi @Andrew_Lencsak ,
Thanks for the detailed explanation.
