Dear all:
Hope you are doing very well.
When I try to select item in the purchase requisition lines I cant view the items defined in the system in the “Item number” field, is there a missing setup???
Please advice
Dear all:
Please advice
How are you trying to select an item? Using the add items it should then show you procurement categories which should hold the items.
Thanks for the reply , but what is the meaning of “Procurement category” with example if applicable , is this a new fuctinallity in AX2012??
No not really from memory, but you really need to read the procurement manual. It is a way of categorising products for easy search using purchase requisitions.
Thank you , I will read the manual.
Thanks a lot.
