The above invoice number can be already found in posted invoices. But customer has entered a the same invoice number again after going in number series for sales invoices and changed the last invoice number. She has entered a new invoice number 2001/00141 (manual entry), now she would like to delete it, navision returns an error as cant delete the invoice header since it already exist. I have tried to delete the record from the sales header table and no luck. Any suggestions. Wajahatullah Khan
Hi, Sales header table has field “Posting No.”. You need clear this field and then you will be able to delete this record. Valentin Gvozdev BMI Inc.
Hi, Thanks for your message. I have already looked at the field posting no, this field under the sales invoice header form is empty. It doesnt contain anything, but still I am not able to delete it. Any more ideas Wajahatullah Khan
hi, You should enter any number in the Posting No. field. In this case you will be able to delete this document. Valentin Gvozdev BMI Inc.
If you can’t get it to delete the Invoice. 1. you will need ro remark a line of code in the OnDelete trigger. 2. delete the documents 3. un Remark the code. //SalesPost.DeleteHeader(Rec,SalesShptHeader,SalesInvHeader,SalesCrMemoHeader); Remember to do this while the Sales team are not using the system As an end user you will have to ask your NSC to remark the code for you, then email you the object. 1. Export the original Sales Header table 2. Import the Modified Table 3. Delete the records 4. Then Import your original David Cox MindSource (UK) Limited Navision Solutions Partner Email: david@mindsource.co.uk Web: www.mindsource.co.uk Edited by - David Cox on 2001 Apr 21 07:47:21
