Can't create new user in AX2012 r3
I’ve created a new user in the AD with the same properties as an exiting AX user.
I can create the new user in AX2012 until I get to enabling the user, ie, I can enter the User ID, User Name, Network Domain, Alias, Account Type, and Default Company.
However, when I try to click in the Enable box, I get a critical stop error “The Active Directory user or group does not exist. Contact your network administrator.”
I have verified that the user credentials are valid and can log onto the domain, so where am I going wrong?
Go to users table in AOT and check SID for this user (if it’s the same as in AD). If not, copy SID from AD to AX table.
Thanks for the reply Przemyslaw Goworowski - it would be useful if I could find the UserInfo table in the AOT - I’m guessing it’s hidden for security reasons.
UserInfo is one of the system tables you will find at the bottom of the AOT under ‘System Documentation’ → ‘Tables’.
Many thanks.
As I can’t create the user in the first instance, the user does not appear in the UserInfo table
How about import the user from Active Directory? Looks like your AX cannot talk to AD domain controller yet.
