Hello;
i have a mandatory field on form, i want that : the user can’t close or save the form if he doesn’t select a value of this mandatory field.
please help me and thank you in advance.
Hello;
have you put the property “mandatory” in the field?
Regards
Hi, On the form → Data Source → Table → field → Properties = mandatory set as Yest
Does it work?
regards
thank you for your help,
i just put this code in database method: validateWrite() : if ( field ="")
throw error (“You must select a value.”);
return ret;
and of course this field mandatory is yes.
with this code the user can’t save or close the form without choosing a value.
regards
