I use AX2012R3 CU8
When I run workflow process (PR process). It’s always show “Stopped (error)” status without any description.
So I try to check the error in event viewer. It show this message.
Object Server 01: An error has occurred in the services framework. Method: AifMessageInspector::AfterReceiveRequest. Error: System.ServiceModel.FaultException: Failed to logon to Microsoft Dynamics AX.
at Microsoft.Dynamics.Ax.Services.AxServiceOperationContext.InitializeSession()
at Microsoft.Dynamics.Ax.Services.AxServiceOperationContext.InitializeContext()
at Microsoft.Dynamics.Ax.Services.AxServiceOperationContext.Attach(OperationContext owner)
at System.ServiceModel.ExtensionCollection1.InsertItem(Int32 index, IExtension
1 item)
at System.Collections.Generic.SynchronizedCollection`1.Add(T item)
at Microsoft.Dynamics.Ax.Services.AifMessageInspector.AfterReceiveRequest(Message& request, IClientChannel channel, InstanceContext instanceContext)
I already config workflow execution account and also add that user in AX. But it still not work.
Then I try to run workflow with “Tutorial_workflowProcess”. It’s work! but when user config that workflow and run it again. It does not work anymore.
How can I solve this issue?
