Hi everybody. I have a problem with my Axapta client: when I run Navision Axapta client and it tries to connect to the application server (AOS) I receive this message: “System does not allow anonymous, unathenticated logon.” What should I do to eleminate this problem?
Hi, If you are not in the same domain as the AOS, you need to set the option “allow anonymous, unathenticated logon” . → on AOS-server → Axapta server manager → select your AOS → click “settings” → go to the “server” tab, there you find the check box Hope it works Pirmin
Thanx a lot, it works! Artem.
