i’m using Dynamics AX 2012 R2.
- I created resource capability by this path “Organization administration->Resource Capability”
| Capability | Description |
| 20 | Paint |
- i created a resource by this path “organization administration->Resource”
| Resource | Description | Type | Vendor | |
| 1002 | Painter | Vendor | V00005 |
after creating the resource, i add the capability “20” to the resource.
- i created the operations by this path “Production Control->Setup->Operations”.
| Operation | Name |
| Paint | Paint the stick |
Click the “Relations” on the Operations form and open the operation relation form, i created a line which contain the item code and route code. click the resource requirement tab, Add a resource requirements like below:
| Requirement Type | Requirement | Operation Scheduling | Job Scheduling |
| Capability | 20 | (check) | (check) |
but when i click “Applicable Resources”, i cannot find any applicable resource in the table. (Resource 1002 should be listed in the table)
i’m pretty sure the resource has the capability list as above. any other option that i have to set up ?
Note: i didn’t set any resource group.
Thanks.
