Hi, can any one suggest me what is the technical issue for the above problem.
When ever i search the empty record it raises the error box showing as " Cannot create a record, record already exist error when searching the empty record "
clear ur usage data
Thanks for the reply.
Can you please tell me the path for clearing, because i am new to ax
Stop AOS.
Delete the .auc file from users\Appdata\ folder
Restart AOS.
Many thanks, Done with above steps, but still problems exists…pls guide me further…
right click on table purchtable and synchronize it
and if still proble occrs thn send me the screenshot of purchtable property
Hi thanks for your guidance.
Still i find the problem. i have synchronized purchTable and PurchTotalSummary table.
I am getting error when i make search of deleted record or if i type any number that is not existing.
If i search the record that exist their is No error.
i have attached the snap please guide.
ur purchid is in user layer in the purchtotalsummary table…
i think some changes are there in that…
take a screenshot of purchid’s property window
have u done any customization in purchtablelistpage form or purchtotalsummary table?
if no thn please delete both form and table so it will directly come into sys layer
have u done any customization on purchtotalsummary table or purchtablelistpage form?
if no thn please delete both the form and table so u will get sys layer on both
Yes there is a customization on purchtotalsummary table…
The initial thing to look at is why it is trying to insert a record into \Data Dictionary\Tables\PurchTotalsSummary (which is resulting a unique index violation)
send me xpo
