I have the issue described here
with NAV 2016 & Word 2013. When I try to Create/open a template Word pops up in the Task bar and closes within a second.
NAV says :“You have canceled the create process.”
Error comes From T5103:
CreateAttachment()
IF "Attachment No." <> 0 THEN BEGIN
IF Attachment.GET("Attachment No.") THEN
Attachment.TESTFIELD("Read Only",FALSE);
IF NOT CONFIRM(Text001,FALSE) THEN
EXIT;
END;
NewAttachNo := WordManagement.CreateWordAttachment("Interaction Template Code" + ' ' + Description,"Language Code");
IF NewAttachNo <> 0 THEN BEGIN
RemoveAttachment(FALSE);
"Attachment No." := NewAttachNo;
IF InteractTmplLanguage.GET("Interaction Template Code","Language Code") THEN
MODIFY
ELSE
INSERT;
END ELSE
ERROR(Text000);
It seems, that NAV can’t create the Word File… Anybody knows why ?
Thank you
