Can we recover passwords in navision
Is it possible to recover password in Dyn Nav
NAV or SQL, and what version?
Its Navision 4.
I think David was asking if the backend was “Navision Sever” or “SQL Server”
gonna throw caution to the wind here and guess that you are using Database Authentication. Cause if you were using Windows Authentication you’d have more problems than just NAV.
T
The backend is Navision Server & using Database Authentication.
Had it been SQL Server then there would not have been a problem.
i’ve heard about that if you denied out yourself from the Navision native database,in this case the MS can send to you a service password and you can login again with that. im not sure it is true for 4.x, but the 2.x version has this feature.
Thats why the question could not be naswered without the correct information. In SQL this can be done through the backend.
On Native C/SIDE database it was possible up till ver 3.70b, but in 4.00 security was tightened and its no longer possible. So you will need to restore from a backup.
Thanks … I will would get the dabase restored.
Thanks I would get the database restored.
