Hello,
I searched in the forum some other post with similar error but I could not find any post with the same error.
When Im trying to start the Dynamics AX Object Server 5.0$01-TM_Ax2009_AO service it appears the following error.
Basically it says that Windows could not start Dynamics AX Object Server in the local server. Error code 100.
I checked the event viewer Applications and it appears the following error
Object Server 01: SQL diagnostics: [Microsoft][SQL Native Client]Login timeout expired. Connect information was: Userid = , Database = [DynamicsAx_TM_DB], Server = [TMSQLPROD\DYNAMICS2009], DSN = , Other =
From the AX SQL Server I checked the Dynamics SQL Services, all were started
Could anyone help mes please?
Thank You.
